Author Topic: Datasheet Database  (Read 13660 times)
Offline JohnS_AZ
    • About.me
Re: Datasheet Database
« Reply #15 on: August 19, 2010, 11:08:30 AM »
Just as valuable as finding a data-sheet is finding out if a given part is actually available.
I find this website invaluable...
http://www.findchips.com/
John
I'm either at my bench, here, or on PokerStars.
Offline peper
« Reply #16 on: October 08, 2010, 07:05:45 PM »
I find this site great for finding datasheets:
http://doc.chipfind.ru/
Can't remember how I found it but it'll search partial part numbers better than Google if you're trying to identify a part.
Richard.
Offline williefleete
    • resistor helper
« Reply #17 on: February 28, 2011, 03:07:33 PM »
i use digchip for most of my sheets usually from boards i salvage. i have a whole folder full of the PDFs from there
im a picaxe fan particularly the 08M's
Offline KJ6EAD
« Reply #18 on: March 14, 2011, 10:21:54 PM »
You can use 2N3904 or BC547 for the NPN and 2N3906 or BC557 for their PNP complements.
Offline Tony R
« Reply #19 on: April 12, 2011, 02:40:35 PM »
I like to use the sites where i buy them from Digikey or Jameco usually, some times Jameco cuts out some information, but usualy the important stuff is there, that or i go to the manufacture.
Tony R.
Computer Engineering Student
Focus: Embedded Assembly Programming, Realtime Systems,
IEEE Student Member
Offline jarcordova
« Reply #20 on: May 05, 2011, 11:40:08 PM »
Hi everyone, I'm new in the forum, North Texas USA, here in my town is Texas Intruments   ;D
Offline phil_jp1
  • Country: ua
« Reply #21 on: November 17, 2011, 01:30:58 AM »
For me the best place to look for datasheets for jelly-bean components - is http://www.datasheetcatalog.com/
Not google, because in datasheetcatalog you can select datasheets from different manufacturers for a given component.
Usually when searching for components I use two websites: http://DigiKey.com/ and http://www.datasheetcatalog.com/ (o, well, and google of course)
But I wanted to tell you about one thing that _really_ speeds up searching for datasheets.
It's a small browser tweak I use - search engines keywords.
For example: If I want to look for BC817 datasheet, I just type "d BC817" (without "", of course) in my browser address bar. And momentarily I'm getting list of datasheets from different manufacturers for BC817 from datasheetcatalog.
The same way I can search for videos on youtube typing: "y SomeVideoNameToLookFor" or on wikipedia "w nuclear reaction", etc.
To add DatasheetCatalog to the list of search engines I've used "Add To Search Bar 2.0" firefox addon (which you can find in list of official addons).
I've included some screenshots - they're pretty much self-explaining.
http://JumperOne.com - Electronic projects, tutorials, hacks, etc.
Offline free_electron
    • SiliconValleyGarage
« Reply #22 on: April 07, 2012, 08:27:48 AM »
What's wrong simply grabbing them from the manufacturers website ? All those cyber-squatter sites like all-datasheet and others do nothing else but make you jump through hoops to get a pdf file. And very frequently they present you the wrong one. I have a lot of instances where you land on these sites and the datasheet isn't even there.
Another problem is that they often have old versions of the datasheet with outdate information or mistakes.
my advice : ALWAYS go to the manufacturers site FIRST. if you don't know the manufacturer : go to Digikey or Mouser websites and type in the partnumber. you will get a list of parts: 99.9 % of the parts these guys sell has the link to the REAL datasheet from the manufacturer. Simply click on the icon there and you will have the latest version.
If it's an obsolete part THEN, and only THEN can you use those garbage collectors, and spewers, like alldatasheet, chipfind. There's even an outfit that sells you a subscription to their datasheet collection. These guess essentially sell you PDF files that they do not own , or are licenced to sell. ( yes the datasheets do carry a copyright by their writers and companies that own them)
Google relly needs to make work of eliminating all those datasheet squatter sites.
Professional Electron Wrangler
Offline Rerouter
« Reply #23 on: April 07, 2012, 08:42:09 AM »
here is a transistor database, it also other than the search function lists near drop in replacements for even some of the more obscure stuff, it also for 90% of the stuff lists relevant datasheets for them,
edit: forgot the link http://alltransistors.com/
Offline SLJ
    • Steve's Antique Technology
« Reply #24 on: November 17, 2012, 09:56:14 AM »
Guess I'll add this handy on-line vacuum tube database for all those tube nuts out there:
http://www.nj7p.org/Common/Tube/SQL/Tube.php
Offline lewis
    • ABELtronics - Electronic Engineers
« Reply #25 on: November 25, 2012, 11:59:56 PM »
Not so much a datasheet website, but this site has got lots of schematics and service manuals for loads of stuff:
www.schematicsunlimited.com
Can you punctuate this so it makes sense? Alan while John had had had had had had had had had had had the better effect on the teacher
Offline hlavac
  • Country: cz
« Reply #26 on: November 26, 2012, 06:53:37 AM »
They corrupt the datasheets, inserting their ads and trashing metadata (set document title to their website name, insert pages and watermarks...). They also pollute the search results with their entries, shifting legitimate manufacturers sites down into oblivion.
I block most of the datasheet sites in my google search for that reason.
I'll take the datasheet from manufacturers site, thank you.
Good enough is the enemy of the best.
Offline victornpb
« Reply #27 on: January 30, 2013, 04:22:16 PM »
I usually just google it like
filetype:pdf datasheet PART
exemple: https://www.google.com/search?q=filetype:pdf+datasheet+ne555
To make life easier i've made a bookmarklet, to find datasheets, this is the code:
javascript:
(function(){if(part=prompt('Search Datasheet','NE555')){
   url="http://www.google.com/search?hl=en&&btnI=I%27m+Feeling+Lucky&aq=f&q=filetype:pdf+datasheet+"+part;
   if(!window.open(url))
      location.href=url;
Or simply go here
Datasheet Finder Bookmarklet
I hope this was useful
Offline UPI
« Reply #28 on: February 24, 2013, 04:08:15 AM »
Very nice!
Offline philpem
  • That Sneaky British Bloke
« Reply #29 on: March 08, 2013, 11:25:25 AM »
Another one worth keeping around:
http://www.electronicsandbooks.com/eab1/manual/index.php?dir=Electronic+Component+Databook+Datasheet%2F
Lots of old databooks here. Unfortunately the site is insanely slow. Like... 56k modem speeds. Not good when the PDFs are 20+MB.
