Author Topic: DC bias on an LCR  (Read 2186 times)
Offline NoodyTopic starter
DC bias on an LCR
« on: February 14, 2017, 04:10:47 pm »
I have noticed a "DC bias" feature on some LCR units. What is it for and when could I need this?
Many thanks. :)
Offline tszaboo
Re: DC bias on an LCR
« Reply #1 on: February 14, 2017, 04:49:10 pm »
Ceramic capacitors (for example) have a high DC voltage dependence. They can drop their capacitance by up to some 70-90% at their rated voltage. Dave has a video on it, watch it.
Offline rfeecs
« Reply #2 on: February 14, 2017, 05:39:40 pm »
It can be used to measure voltage dependence of the capacitance of a diode.  A varactor for example.
Offline dacman
« Reply #3 on: February 14, 2017, 11:09:50 pm »
The capacitance of a power supply filter could be checked at actual working voltage if within range.
Offline Smokey
  • Not An Expert
« Reply #4 on: February 15, 2017, 12:12:38 am »
The following users thanked this post: AlfBaz
« Reply #5 on: February 15, 2017, 11:19:11 am »
Thanks guys! I'll watch Dave's video now and will study-up on the rest afterwards.
It seems that the Applent AT2816 LCR that I was looking at getting, doesn't have a DC bias feature, yet some cheaper alternatives, do. I see why this is useful, so should I be considering the lack of DC biasing as a strong negative in getting the Applent? It's been 25 years since I last seriously played with electronics. I don't recall DC biasing being a feature back then.
Offline tszaboo
« Reply #6 on: February 15, 2017, 12:05:23 pm »
Depends what you are going to use it for. For inductors and resistors, it does not make a lot difference. For capacitors, you can just select ceramics which are known to behave well, or have datasheet with the information available. For a capacitor, it is a go/no-go test anyway.
