It's me again :p
I've got a simple power "bank" set up which currently consists of one 18650 battery holding about 1300mAh, a boost converter, and a micro USB cord.
I've got it all worked properly as far as I know (triple checked polarity all along the circuit with my DMM) and my phone is happy with the output, but both the battery and the converter get uncomfortably hot. It's not quite enough to leave a red mark, but it is enough that you can't hold it for too long.
The chip on the converter is an MT3608 which I read over the datasheet for, but there was no info on temperature other than 155° C thermal protection cutoff.
Is the heat from such a small voltage boost normal? I expect a lot of heat from higher voltage jump , but both the module and the battery are getting hot. I wanted to be sure I wasn't misusing it.
