Hello!
I have couple of questions regarding DC-DC converter, but first of all I would like to present you with my problem.
So thing is that i have small 2 stroke motorcycle which has CDI ignition. But problem is that it's High voltage coil which charges capacitor is failed and new part is very expensive, so I've come up with idea to build dc dc converter which would generate that voltage(about 250-300V).
I found this schematic on internet for the complete DC CDI, but thing is that I want to use only inverter from that circuit because I want to keep my original CDI(except spark, original CDI controls power valve in exhaust)
http://www.transmic.net/DC-CDI-v20/DC-CDI-Schematic.pdfSo this is part of the schematic that I would use:
My question are:
1. I was thinking of adding some voltage protection because maximum voltage taht my cdi can handle is 400V( i dismantled one old cdi and found that capactior is 1uF and rated on 400V)
I think that 300V would be enough so I added one varistor in schematic which should serve purpose, but I don't know is that enough, and what else should i add for maximum reliability and protection?
2.On this shematic for inverter which is basically same:
http://www.sportdevices.com/ignition/inverter.htm Is staded that "The last 1N4007 diode is necessary to load the capacitor with the current provided by the transformer" I was planing to replace 1N4007 with some shottky diode which are faster. On my shematic this diode is connected beetween CDI ignition output and ground.
3. Biggest problem is that HV coil generate voltage only when magneto passes near it and with this design voltage would be generated all the time and it would needed to be somehow wasted, otherwise there will be huge voltage build up. For that purpose i put varistor, but I don't know is that enough.
4.On original transmic shematics that problem is solved with pin 1 of the UC3845 which turns on generator when activating scr, so all voltage that is induced goes to the spark.
If you have any advice feel free to post because I'm not so competent in analog circuits and if I could make this, it would save me a lot's of money,and also because this is common problem on motorcycles it would help other people too.
Best regards and thanks in advance.
Josip
