Do you have an oscilloscope? For motor control, you'll spend a LOT of time guessing if you haven't got one!
There are a million possible reasons for your Bridge not working with the larger motor, and in fact, it probably doesn't work that well with the small one! As mentioned, for typical small motors the series resistance can by high, and dominate the series impedance, but once you get up into big motors (or more acurately, low turns, high inductance ones) then the impedance dominates. At this point, extremely high currents can flow in very short time periods, causing all kinds of issues.
We could all guess why your circuit isn't working for the next 20 years and still not be correct!
Sorry, if this sounds "negative" but i am always amazed by how many people start messing with motor controllers without basic knowledge and the necessary tools to be able to investigate the performance of their device. I think because you can do electronics on the bench, people think it is easy. I mean, no one would try to make say and internal combustion engine on their bench (well, only a few people) and yet lots of people try to make an electric one.......)
