Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
DC Motor forward / reversing and limit switches question
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DC Motor forward / reversing and limit switches question (Read 2158 times)
Chris Wilson
Super Contributor
Country:
Race car engineer, dog lover, hoarder.
on:
March 20, 2018, 07:19:04 pm »
I have a low RPM (planetary geared) 12V DC motor driven variometer in my LF transmitting set up, outside in the antenna loading coil enclosure. Whilst I know how to wire an in the house 3 way switch after the in house power supply, using a two core cable direct to the motor to forward and reverse it, that does not give me the over travel safety of a pair of limit switches. Is there any way to not have to use more than a two core cable to outside and have a pair of micro-switch limit switches on the variometer to stop over travel in either direction? I suspect not but have managed to get myself confused now
If I have to use a multi cored cable, what's the minimum number of cores I need to achieve this please? Thanks for any help!
Logged
Best regards,
Chris Wilson.
Andy Watson
Super Contributor
Re: DC Motor forward / reversing and limit switches question
Reply #1 on:
March 20, 2018, 08:26:08 pm »
Is it a straight-forward DC motor - on/off control ? No PWM or such like?
Just put the two limit switches in series with the motor and bridge-out each switch with an appropriately oriented diode - such that it doesn't get stuck when it runs off the end.
Logged
Chris Wilson
Chris Wilson
Super Contributor
Country:
Reply #2 on:
March 22, 2018, 05:46:52 pm »
Yes it's a basic DC motor run off a basic DC supply. thanks Andy, simple when you know how, that should be pretty straightforward to implement, appreciated!
Logged
Best regards,
Chris Wilson.
David_AVD
Super Contributor
Country:
Reply #3 on:
March 24, 2018, 11:29:05 pm »
I think this is what you're asking for?
Logged
Chris Wilson
SeanB
Chris Wilson
Super Contributor
Country:
Reply #4 on:
March 24, 2018, 11:34:36 pm »
Thanks David, that's it, I am just putting the finishing touches to the mechanical mounting of the switches, cheers!
Logged
Best regards,
Chris Wilson.
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
