The op-amp in question is running from a single supply rail, so the output can not swing below ground. In order to cope with an audio signal in this case you need to impose a DC offset, and for a rail-rail output amp running from 5v, you'd want this offset to be close to half the supply rail to maximise the output swing.
Since the inverting input to the op-amp is AC coupled, the DC gain at the non-inverting input is 1. Therefore applying 2.5v to the non-inverting input gives 2.5v on the output.
