I spent an hour trying to get an oldish touchscreen LCD panel to do anything!
It would power up, but never display an input signal..... I replaced all the electrolytic capacitors, as the screen was getting on a bit, and had spent a fair bit of its life in a vehicle...
Turned out, the 12volt, 2amp power supply was dropping to 9volts with a 1amp load, so the screen was never powering up properly...
Tried it with a 12volt, 1.5amp supply, and it worked fine...
