Im trying to create a small inverter that can make a small AC voltage to play with filters, I have some transformers but I would like to control the proporties of said waveform. I was thinking a H-bridge would work, but could you explain how an ocilliator would create an AC voltage from DC? And why wouldnt an H-bridge work?
It sounds like you're describing an application for a function generator. It's an already-built box that allows you to create waveforms of varying properties, making it easy to control the amplitude and frequency, as well as the shape.
The classic way to study filter design is to use a function generator to create an input signal, put a filter of some sort in the middle, perhaps put a load on the output, and use a two-channel oscilloscope to look at the input and output waveforms of the filter. More channels of a scope might be useful to look at intermediate points in the filter.
An H bridge is a circuit that allows you to switch the polarity between a power source and load. It might be used as a piece of an inverter, or perhaps even part of a function generator, but you need something to drive it. It needs control signals to drive the switches on the legs of the H, plus you need some sort of input power supply, perhaps with a controlled waveform. If the input power is a steady DC, the H bridge can only generate squarish waves of alternating polarity DC, and it can only do that if you've got some kind of oscillator driving the switches of the H bridge. Many times, a microcontroller of some sort is used, and the oscillator that ends up driving everything is the clock signal for the microcontroller.
I don't know what your budget is, nor do I know how much you want to learn about generating AC waveforms versus learning about filter design. If you want to concentrate on filter design and can afford a function generator, I'd recommend getting one. There are a number of choices, from basic kits built around a AD9833 DDS chip, through full-featured arbitrary waveform generators. If you're willing to be limited to audio frequencies, a PC or smartphone can be used as a reasonable function generator, within limits, and it may be free. Look for "function generator software" on your favorite search engine, and you'll find lots of examples.
If you want to learn how to generate AC signals instead of acquiring a black box that will do it for you, that's a good thing to pursue, as well, but it's a different goal. Some terms to search for: "BJT Astable Multivibrator", "555 timer", and "Wien Bridge". Lots more types of oscillator circuits are described here:
http://en.wikipedia.org/wiki/Electronic_oscillator#Circuits .
