I have built a DC to DC buck converter on a breadboard, so none optimized lead lengths. I used the circuit attached. The chart, also attached, for deducing inductor values for 50V in and 24V out do not correlates though. I used what i have on the breadboard, a 680uH and a 1000uH. The 680uH gives the waveform superimposed on the output as in the scope photo also attached. I am using a x10 probe and the scope is not compensating for that, so multiply the levels by 10 please. Using the 1000uH I see a diminishing ringing sine wave also superimposed. How critical is inductor value, and what do people recommend I try? The 680uH is wound on a ferrite rod core, and I could remove some turns. It's rated at 1.5 amps DC. The 1000uH is wound on a toroidal core. I am seeing the square wave with a 50 Ohm load resistor across the output so about 0.5 Amps being drawn. That is about the maximum i expect the circuit that needs 24V to draw. I am not using the optional ripple filter. Thanks.
