Yes i needed a voltage above the 7812, although 24 volts is a bit on the high side, its all i had at the time that could handle up to 10 Amps. Athough i was testing single pass trasistors up to 5 Amps. But also paralleled 4 x transistors. The TIP2955 transistors i used back then where fine with an smps input. But trying first a single MJ11015 darlington underload produced some unstable results. I wandered if it was the smps input.
Two smps where in series to give me more than just 12 volts. I'm not convinced it caused the insability issues, but don't know. I might have to try again with a single MJ11015 and a linear input. On the plus side the high gain of the MJ11015, there was no voltage sag or drop up to 5 Amps. The oscillating was intermittent, voltage would drop a volt then climb a volt, then go stable if load was reduced. The smps where just a means to an end.
If it was the smps input causing instability that would be great, because its unlikely to do it with a linear input. The desirability of the MJ11015 transistor is its ability not to drop much voltage under load, if i could get it stable. I've got another redundant linear psu that needs repair, i would use an LM317K and the MJ11015, in hope its stable..
