I'm working on slapping a couple of big (120Ah) deep cycle lead acid batteries on a Eaton Powerware 5115 1000VA 230V UPS. The integrated battery charger seems to put out 27.50V and about 1 A of charging current. That's not enough for a 120 Ah 24V battery bank. So my idea was to simply put one of those MeanWell NES-350 SMPS directly in parallel with the UPS battery input and set it to 27.6V and set the current limit to around 10A by changing a magic resistor inside
So I did all that and measured that the UPS charging circuitry now was pulling about 0.2A from my MeanWell at 27.6V. Great it works, the UPS starts happily and passes self-test and is able to idle in that state for hours without any smoke.
Now the only major problem I have with this is that when the UPS is hooked to a wall outlet that has safety earth grounding, an AC voltage of approximately 150VAC appears between the battery terminals and earth. I even tried measuring with a low impedance analog multimeter to see if there is any current behind this voltage and was able to pull atleast 2mA without the voltage dropping at all, so that's a problem. I'm guessing the battery charger is not isolated from the mains input :\ Using a power cord without grounding takes care of this problem, but that's not good practice now is it.
As I have my external charger I don't really need the integrated one at all, so completely disconnecting it would be great... if only I could figure out how to achieve that..
A diode between the battery and the UPS takes care of the DC charging voltage from reaching the battery terminals but not the AC component that is the problem.
Any suggestions what I should do? I'll attach a picture of what I have so far. There's the MeanWell NES-350-27 wired in parallel with the battery input of the UPS trough a 50A current shunt board that also monitors the voltage. That all is in parallel with the nominal 24V stock battery pack wired with alligator clips just for testing :p The MeanWell is powered from 230VAC coming from inside the UPS (I just tapped to the IEC mains input connector)
Here's the teardown with pictures from inside the UPS:
https://www.eevblog.com/forum/product-reviews-photos-and-discussion/teardown-eaton-powerware-5115-1000va-usb-230v
