I picked up a broken HP 215A pulse generator on eBay and have been trying to restore it to working order. I was able to adjust the power supply to specified values for all rail voltages except the +40VDC line. That one won't go higher than 35V or so, and has excessive ripple voltage (>2V) as well.
Can you take a look at the attached schematic and offer suggestions of in-circuit tests I can do to isolate the cause? I would prefer not to replace all electrolytic capacitors just because they are old, but my guess is that at least one is bad. I checked to see if C302 is shorted, and it was not. C303 is the big cap on the +40V line. At least on the surface, it looks fine, as do all the components on the board.
Happily, the -40V side of the power supply is working fine and has a close symmetry to the positive side, so it's easy to compare behavior of components on one side vs. the other. However, I want to avoid removing components from circuit if at all possible.
Any suggestions?
Thanks!
- Ken
