Author Topic: Decoupler for my function generator?!  (Read 1918 times)
Offline chrisstra84Topic starter
  • DO2EC
    • Ortsverband Werl O49
« on: March 07, 2015, 07:55:03 pm »
Hello guys!
I have made a measurement with my amplifier. You can see it in the picture below. On the left it’s ok! But on the right it’s a “problem”.  I have figured it out by accident.  :palm:
Fortunately, nothing is happened because there is a protection in the amp!  :-BROKE
So my question is how can I protect my devices? What can I do to make my function generator floating? So I want to decouple the generator. What is a good decoupler or ground loop isolator for the output? It is generally possible?
Christian
Online Zero999
  • 0999
Re: Decoupler for my function generator?!
« Reply #1 on: March 07, 2015, 08:25:42 pm »
If it's just audio, you could use an audio isolation transformer.
Offline max666
  • Country: at
« Reply #2 on: March 07, 2015, 08:34:06 pm »
And isolation transformer, which we discussed in your other thread Safety first with oscilloscope & Co., would prevent that problem.
And you told us you've watched “How NOT to blow up your Oscilloscope”!!! Or did someone not pay attention to what Dave was saying?!
  • DO2EC
« Reply #3 on: March 07, 2015, 08:56:24 pm »
Yeahh,
I have seen it. But the generator was out of my mind. So the amp itself has no mains earth connection. And so the DUT was not mains earth referenced. But I have made a new one over the generator and so I have closed the circuit.   |O
So, what kind of audio isolation transformer can I use? Or is there any kind of decoupler integrated in a BNC adapter?
So you can learn, read, watch and listen to any kind of electronic stuff, but you will never forger a mistake made by yourself.
I hope so. :phew:
Christian
  • DO2EC
« Reply #4 on: March 07, 2015, 10:06:32 pm »
Is this a possible way?
http://www.amazon.com/Gino-Female-Coaxial-Ground-Isolator/dp/B0038O9R86
I search this kind of ground loop isolator with input/output resistance of 50 ohm. Or can I make one by myself? What I need for this?
Christian
Offline VictoriaGuy
« Reply #5 on: March 07, 2015, 11:15:15 pm »
I'd use something like this:
http://www.hammondmfg.com/560.htm
for audio isolation.
It helps that I have some on my parts shelf!
