Dear all,
I would like to use the CCFL inverter of my girl friends old broken laptop as a HV source. However, I cannot find the datasheet of the 20 pins controller (MP1028EF) for the life of me. I found datasheets of the 1026 and 1029, but those appear not to be pin compatible, since the pins which should be enable on the 1026 and 1029 are not connected to a pin on the connector. Does anyone know the pinout of this IC?
Thanks in advance!
