Author Topic: Demod on Rigol DSA815 TG  (Read 3718 times)
Offline geggi1Topic starter
« on: October 05, 2014, 01:55:07 am »
Just got my new toy  :)
I have been playing about with it for a few days.
Today I tested the demod fonction but can not get any audio form the speaker jack in the fornt.
Is there somone here that can cive me some hits.
Signal level and impedance ?
Stereo or mono jack?
Ring center and tip if tereo jack?
Regards.
Geir
Offline Rory
Re: Demod on Rigol DSA815 TG
« Reply #1 on: October 05, 2014, 03:38:41 am »
Did you remember to turn the earphone ON, in the demodulator menu?  It is not turned on by default.
Offline Rory
« Reply #2 on: October 05, 2014, 03:48:24 am »
This Rigol document will answer your questions.
« Reply #3 on: October 05, 2014, 08:34:09 am »
Tanks that helped a lot.
I'll get a mini jack with mono and give it a new try.
Do you know anything about the signal levels?
Is it enought to drive a speaker directly or will i have to use a speaker with a amp?
Online HighVoltage
« Reply #4 on: October 05, 2014, 09:05:01 am »
I have been using a standard stereo PC headset on the DSA815 and it works well.
The sound comes out on both speakers of the headset.
As was said already, make sure to turn the Earphone ON and set the Demod Time to a larger than the default 100 ms value
This way you can very easily listen to all FM stations, at least here in Germany.
Offline XFDDesign
« Reply #5 on: October 06, 2014, 09:31:35 pm »
The audio output on that jack is designed around a 10kOhm load, not headphones directly, so plug it into your computer instead of headphones.
Offline IconicPCB
« Reply #6 on: October 07, 2014, 01:28:26 am »
zero span and tuned in the carrier?
Bandwidth wide enough to not reject the signal?
