I think you will be surprised by how much maintenance a vacuum desoldering station needs. When they are working, I think they work a lot better than a Soldapullt,
but there's definitely a hassle factor.
I find that the HAKO 474, with the short heating throat, is great to clean and use. The "pencil" versions are a total PAIN, and have a higher failure rate.
The HAKO FM204 is a POS, very long throat, always clogs and you have to replace the entire heater each time. But none of that compares to the -
JBC abortion ! Worst desoldering station I've ever bought.
If you use a lot of through hole components, my opinion is that a good one is a MUST. Hot air stations can also be problematic. First, yu start of with a huge array of
tip shapes, so you direct air only on the pins, which is GREAT in theory, but it turns out that it's noty that simple. Often, the solder is NOT where the tip directs it,
and if you move it one way, the other end heats the IC (square packages are the worst), and that is what you were trying to avoid (unless you don't care if the
chip is saved). So then you switch to single row tips, and quickly move around all 2 or 4 sides. That sort of works ok, except when they use high temp solder or glue.
So then you hold the IC with tweezers and apply slight upward pressure. You can spend years screwing around with different methods :-)
Other flood the IC with very low melt solder, use a broad air flow to melt it and tweezers to pull up the IC. That actually works well.
So the bottom line is, how many, how often, what variation of ICs do you expect? Many labs have all 3 tools, plus the low temp solder etc etc
