To detect far infrared such as that emitted by hot objects, you could use a bolometer. It's basically a thermopile with one end painted black so that it absorbs the IR and gets heated by it. Being in close proximity to the hot iron tip might also cause it to be warmed through the air, possibly reducing temperature accuracy, though I doubt that would matter for your application.
