Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Determine read cycle speed of eeprom
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Determine read cycle speed of eeprom (Read 1389 times)
Supreme
Newbie
Country:
on:
November 29, 2016, 09:05:05 pm »
Hi, I have this chip:
https://4donline.ihs.com/images/VipMasterIC/IC/TOSC/TOSCS25929/TOSCS25929-1.pdf?hkey=EF798316E3902B6ED9A73243A3159BB0
I want to dump its memory using programmer also i want to analyze it using oscilloscope/logic analyzer , what is the cycle speed Mhz/Sample rate of the devices in order them to work with this chip?
If it is possible, please explain how you calculated the result.
Thanks.
Last Edit: November 29, 2016, 09:14:08 pm by Supreme
Logged
amyk
Super Contributor
Re: Determine read cycle speed of eeprom
Reply #1 on:
November 30, 2016, 03:43:53 am »
Look at page 5. This is a NAND flash, read and write cycles are internally timed and may vary in length depending on the age/wear on the blocks.
Logged
Supreme
Newbie
Country:
Reply #2 on:
November 30, 2016, 06:07:28 pm »
Which device can dump the contents of the NAND chip? and what its specifications should be?
Logged
amyk
Super Contributor
Reply #3 on:
December 01, 2016, 03:33:45 am »
Anything with enough I/Os... and is fast enough that you won't be annoyed waiting for it to finish reading. Even an Arduino will do it if you don't have anything else.
http://hardcoreforensics.com/blog/2012/01/02/arduino-mega-direct-reading-of-a-nand-flash-memory-chip/
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
