Author Topic: Determine transformer amps?  (Read 6158 times)
Offline cio74Topic starter
« on: November 29, 2013, 03:56:30 pm »
Hello,
I dismantled an old Sherwood rd-6106r Av transceiver rated 5 x 65W audio power. It has a nice big transformer with 2 x 32V outputs, thick wires. Plus lots of other small wires on the other end.
I can't find the schematic of this transceiver, any idea how I can safely determine the output current?
Thanks.
Offline Kremmen
Re: Determine transformer amps?
« Reply #1 on: November 29, 2013, 04:46:02 pm »
One method is to rely on the fact that iron core transformers are all dimensioned pretty much the same. So simply weigh the xformer and look up what is the average power rating of similarly heavy transformers. From the power and known secondary voltage you can calculate a pretty close approximatiuon for the max secondary current.
For multiple secondaries you can estimate the individual currents as fractions of the total based on the wire cross sections. It will not be spot on, but close enough if you are conservative in your usage.
« Last Edit: November 29, 2013, 04:48:44 pm by Kremmen »
Nothing sings like a kilovolt.
Dr W. Bishop
Offline Rory
« Reply #2 on: November 29, 2013, 06:29:01 pm »
This article says you can determine the approximate VA rating of a transformer just by knowing its weight and primary resistance.
http://sound.westhost.com/xfmr2.htm#s113
« Reply #3 on: November 29, 2013, 08:27:21 pm »
I have weighted it, 3.5 kilos, 8cm height and 10cm diameter. 5 ohm primary resistance and 2 x 0.45 ohm on the secondary windings.
Looking into that web page, it's between 300VA and 500VA which makes sense considering the total audio power.
Assuming 350VA, 32V in secondary, I am looking to have it correctly operating at about 10A under load?
« Last Edit: November 29, 2013, 08:33:23 pm by cio74 »
Offline Smokey
  • Not An Expert
« Reply #4 on: November 30, 2013, 03:51:30 am »
This procedure requires two identical transformers.
1) Take transformer #1 and hook it up to a current source.
2) Keep turning up the current source until transformer #1 smokes.
3) Once transformer #1 smokes, turn off the power supply and note current level.
4) Discard transformer #1
5) Use transformer #2 below the current level that transformer #1 smoked.
6) Profit!!!!
Offline tehmeme
« Reply #5 on: November 30, 2013, 08:22:50 am »
6) Profit!!!!
 :-DD
Offline kripton2035
« Reply #6 on: November 30, 2013, 09:09:59 am »
6) Profit!!!!
like it too ... is this method in relationship with your nickname ??? ;)
Offline Smokey
  • Not An Expert
« Reply #7 on: November 30, 2013, 10:10:58 pm »
We actually did smoke a potted in transformer at the office once.  Of all the nasty burnt electronics smells I've smelled, that had to be in the top 3.  It took a solid week of airing out before that smell went away.
I guess I really should have put a note in my procedure:
NOTE) procedure should be performed outdoors or under a fume hood, or in the office of someone you REALLY don't like.
« Reply #8 on: November 30, 2013, 11:10:34 pm »
6) Profit!!!!
Do you think you're funny? Really, do you? Your post is so meaningless and stupid, I was asking for a bit of help not for a clown.
Offline Skimask
« Reply #9 on: November 30, 2013, 11:22:37 pm »
It wasn't meaningless.
I laughed.
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline c4757p
  • adieu
« Reply #10 on: November 30, 2013, 11:28:42 pm »
Wait... how can you concentrate on transformers when you've got that massive stick so far up your ass? You should be in the hospital, not at the workbench... :wtf:
Offline GK
« Reply #11 on: December 01, 2013, 12:08:31 am »
From the transformer size/mass guesstimate the regulation (little <5VA transformers can have as bad as 30%, big >500VA 5% or better). Measure the unloaded output voltage. Load the secondary until the output voltage drops by the estimated regulation %.
Alternatively, the transformer may have its secondary output voltage labeled. In that case you do not have to guesstimate the regulation %. Unloaded, you will measure a secondary voltage higher than stated. Simply load the transformer until the secondary voltage drops to the rated value - however for accurate results make sure to measure the primary voltage as well (mains voltage can vary) and take the subsequent scaling factor into account (actual primary voltage / rated primary voltage) if a Variac is not available to adjust it. Also be sure to use a quality meter that measures AC I/V in "true RMS".
« Last Edit: December 01, 2013, 12:14:38 am by GK »
Bzzzzt. No longer care, over this forum shit.........ZZzzzzzzzzzzzzzzz
Offline Skimask
« Reply #12 on: December 01, 2013, 01:23:21 am »
Where is that damn like button?
I turned it on.
Offline c4757p
  • adieu
« Reply #13 on: December 01, 2013, 01:25:01 am »
Up his ass along with the stick, most likely.
Offline Skimask
« Reply #14 on: December 01, 2013, 01:28:36 am »
Well then...I ain't reaching up there...or is it "down there"?
I turned it on.
Offline TMM
« Reply #15 on: December 01, 2013, 02:04:50 am »
Offline peter.mitchell
« Reply #16 on: December 01, 2013, 03:08:18 am »
This is my prefered method, however, i like to run them loaded like that for a while and measure temperature rise too, just incase.
