I have two motors from a CD-ROM drive. One has 4 wires, the other 11 wires.
Are these motors DC?
I can put the drive back together to test if necessary, though I'll need some advice on which wires to test.
I wish to make X & Y drive rails for a mini CNC drill. So the first smaller motor can already do this job.
The second motor I wish to use to get different rotation degrees. It does not need to be fast, I could easily replace this 11 wire motor with a simple DC fan motor if you think that would be less hassle?
These motors do not appear to show any voltage ratings on them.
