Author Topic: determining THD for generator  (Read 3965 times)
Offline littlebillTopic starter
« on: May 11, 2016, 02:32:47 pm »
is there any way to figure out the THD value for my generator? or how its calculated?
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: determining THD for generator
« Reply #1 on: May 11, 2016, 03:58:48 pm »
You use a meter that can measure harmonic distortion. Such as an Fluke 435.
« Reply #2 on: May 11, 2016, 04:00:43 pm »
so a normal oscilloscope can't do it?
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #3 on: May 11, 2016, 04:26:31 pm »
I'd assume such thing is possible using FFT.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: May 11, 2016, 04:45:47 pm »
if you know what you are seeing and limitation of the entry level scope... analyzing in FFT domain may give you some clue. for example, using http://www.soasystem.com/download/visadso/ a file of pure sine signal in csv format, generated from a simple computer software, not from imperfect real world, is provided in sample directory. you may import the file in (a) raw data and then (b) byte data, with each type of data you may plot the FFT and look at the THD of both. with theoritical perfect sine captured as real data, the THD is 0%. but when downsampled to 8 bit data, the THD is 0.3205%, this is the best a dso can give you, assuming your generator is a perfect sine generator with 0% THD, and the dso has a perfect sampler system, for example sampling period dT(n) = dT(n+x) with x is positive integer, no variable offset in the ADC etc to not screw up the Nyquist sampling requirement... when you have a little bit idea about this, ie your scope limitation, and how it looks like for a perfect sine's FFT downsampled to 8 bit on the screen, then you may take necessary action to compensate or subtraction, when you do a real measurement with your scope and the VisaDSO or any other SW capable of doing large data set of FFT like matlab etc. some other people swore by the averaging function of the scope, but i'm not one of them at this particular application. i may use it, but in conjuction with non-averaged signal, just to check the validity or to get an idea how far i may be off. but then, this is a poorman method, the proper way is to use the dedicated instrumentations.
Offline danadak
« Last Edit: May 12, 2016, 12:08:24 pm by danadak »
Offline joeqsmith
« Reply #6 on: May 12, 2016, 11:09:28 am »
Is the "generator" you want to look at a 3 phase 440V 40 KW diesel at 50Hz?
I made a video showing my attempt to use a DSO to make some decent AC line measurements.  Part of that was THD.
