OK, so I figured out what was wrong. When I first put this kit together, the nut holding the 2kOhm potentiometer seemed to be damaged and I had to really torque it on. In doing so it appears that I pulled one of the legs enough to cause a break in its trace.
I soldered a wire from the leg past the damage on the trace and it works as designed now. Don't know if its really usable now but I'm happy to have located the problem.
Thank you all for your help and guidance.
Bill
