It was a strange question. Voltages don't travel across resistors
If anything, current is the thing that travels. Current must travel from V1 through both resistors and into (or out of) the opamp output. For an ideal opamp, no current goes in or out of the inputs.
V2 does the same thing, but the current goes through two resistors to ground instead of the opamp output.
You are missing the point that the opamp actively DRIVES the output based on the difference between the + and - output. Should the opamp output be at the same voltage as V1, there is no "travelling" taking place, since the voltage across the two resistors will be zero. For example, when V1 = 1 volt and V2 = 2 volt: V2 is divided in half by the two resistors, so the + input sees 1 volt. The opamp will drive the output to 1 volt to make the - input be also be at 1 volt.
Maybe it's easier to see with a plain inverting opamp with the + input connected directly to ground. With 1 volt in, the opamp drives the output to -1 volt, so that the midpoint that's connected to the - input sits at 0 volts. There will be a "travelling" current (2 volts across two resistors), but as long as you're within the valid (voltage/current) range for the opamp, the input voltage will not magically travel to the output. The opamp output is typically a low impedance (let's say 1 ohm) and the resistors are typically much higher (let's say 10000 ohms). So unless you send crazy high voltages in, the opamp gets to decide what comes out and not the voltage you send in.
