This is my first post and I'm learning as I go. I'm still a n00b at all this. I have been watching Dave's videos and trying to teach myself as I go along.
I have been messing with an op amp in differential mode.
I am using an OP177 ultra precision op amp.
http://www.analog.com/static/imported-files/data_sheets/OP177.pdfMy issue is that for whatever reason I cannot get the circuit to output 0 volts like it does in the simulator. I get a minimum reading of 0.689 volts. Am I doing something stupid?? I have noticed that this isn't advertised as a rail to rail op-amp is that the reason for this?
I have tried the trim feature of the chip, however it only trims a tiny range. No where near 0.
I'm trying to make a circuit that can read battery voltage 8-16 volts. If the battery is below 8 volts its garbage so I want to maximize the ADC by only measuring the voltage over 8 volts. I'm trying to keep the cost of the project down by using the atmega ADC.
EDIT: I should note that it the circuit does work. It just isn't work as I expected. I'm losing a significant portion of my ADC range with that 0.689 offset
EDIT2: I also tried matching resistors thinking it could be an issue there. Went through a bunch and found matching resistors.. No joy
