Author Topic: Difficulty in VReg selection  (Read 1104 times)
Offline aurmerTopic starter
  • Insert text here.
« on: October 28, 2016, 07:52:31 am »
My Mouser search powers are failing me. Or is my ELEN 101 why I fail?? What type of Voltage Regulator am I looking for with these requirements? I started with looking LDO Vregs, but all I was finding were ones that change Vout based on Vin. Does such a thing exist?
Requirements:
Iout: 150mA sustained (even 100mA sustained?)
Vin: 3.3V - 5V (as low as 3.3V isn't realistic, but trying to go as low as possible for 'acceptable Vin' because backup battery is 3 AA cells. The lower it will accept power, the longer it can run on battery.)
Vout: 3.3V - constant across Vin range.
If I just asked the wrong question, shame on me for asking before I was ready for help. Please be kind and direct me to a resource which will teach me the question I SHOULD be asking. Thank you.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Difficulty in VReg selection
« Reply #1 on: October 28, 2016, 07:57:01 am »
LDO's wil always drop some voltage. And they often turn off when Vin < Vout+1.
You could use a buck-boost regulator. Such as: TPS63060.
