Author Topic: Digital input on DAC? (datasheet confusion MP7531JN)  (Read 2082 times)
Offline SArepairmanTopic starter
  • wannabee bit hunter
« on: July 15, 2013, 10:01:55 am »
http://www.datasheetarchive.com/MP7531JN-datasheet.html
I am testing this DAC and It says on the first page that Logical 1 at digital input steers current to Iout1.
I set the dac up with a IV converter op-amp using Rref and the Iout1 works fine, but I have no idea how to activate Iout2.
What do they mean by digital input? When I leave it as it is and measure Iout2 it goes from 12-14 volts.... did they forget to add a pin?   :wtf:
I thought it might have meant that Floating-Ground = output 2 and vdd-ground = output one but I tried it and it does not work.
I also tried grounding and vdding Iout1 and it does not change Iout2, where the steps change it from 12 to 14
« Last Edit: July 15, 2013, 10:07:11 am by SArepairman »
Online PA0PBZ
Re: Digital input on DAC? (datasheet confusion MP7531JN)
« Reply #1 on: July 15, 2013, 12:58:59 pm »
Another multiplying DAC: http://www.ti.com/lit/ds/slas061d/slas061d.pdf
Strat reading from page 5 how these things work, you are supposed to use both outputs.
About the "Logical 1 at digital input steers current to Iout1" see the diagram on the first page of the document you linked, the inputs control the switches.
« Reply #2 on: July 15, 2013, 05:25:09 pm »
I realized that in the schematic the second output is grounded so I don't think I will even bother to test it, I can't imagine they need to use an abnormal dac for generating a sweep wave form.
There is just a buffered voltage reference for vref and a IV converter+Pi RC filter for Iout1 and Iout2 is grounded, I don't think its doing anything odd.
I guess the multiplication feature is kind of odd ball... I don't believe its used here.
Maybe the company bought 50,000 of them and they decided to use it instead of a traditional dac?
« Last Edit: July 15, 2013, 05:42:28 pm by SArepairman »
Online PA0PBZ
« Reply #3 on: July 15, 2013, 06:19:49 pm »
I had a broken MP7528 in my Marconi 2022 signal generator, which was there to tune the output notch filter. I suddenly noticed a lot of spurious in the signal and it turned out to be this DAC.
That one is a dual multiplying 8 bit dac, where the second half is used for jitter control. I never found out if they are using the multiplying function in there, but after replacing the DAC everything was fine again.
