What you really want to do is to improve on your signal to noise ratio. adding an a rf amp will add additional noise, that will take you nowhere (unless you have to use really long antenna cables, in which case you have to mount the amp right at the antenna, not in your living room). If you have to deal with weak signals, build or buy a better antenna with higher gain and use high quality, low-loss coax...
