Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Digitally controlled step-up converter instead of using resistor feedback
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Digitally controlled step-up converter instead of using resistor feedback (Read 1519 times)
DanioIO
Contributor
on:
January 31, 2015, 11:24:48 pm »
I need to control a output voltage from a step-up converter using a microcontroller is it possible to use a DAC instead of a resistor feedback in this case?
Logged
zapta
Super Contributor
Country:
Re: Digitally controlled step-up converter instead of using resistor feedback
Reply #1 on:
January 31, 2015, 11:36:03 pm »
You still need the feedback for the stabilization but you can inject signal from the DAC that influence it. What is your original circuit?
Logged
theatrus
Frequent Contributor
Country:
Reply #2 on:
January 31, 2015, 11:40:15 pm »
An op-amp summation stage from the feedback network with your DAC injected is one approach that would work for tweaking the value. Tweaking the ground reference point is another approach (though not directly from a DAC output).
What is your circuit so far?
Logged
Software by day, hardware by night; blueAcro.com
DanioIO
Contributor
Reply #3 on:
February 01, 2015, 03:58:07 pm »
Can this circuit do its job? I want to control LTC3862 which has a feedback reference set at 1.22V.
Logged
theatrus
Country:
Reply #4 on:
February 01, 2015, 04:52:55 pm »
Your op amp is missing a feedback network but you have the right idea for a difference amplifier.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
