Is there a DIP package alternative to the SMD JFET input general purpose Op Amp type TL071 available that would be electrically identical please?The info on the TL071 is available here: http://www.ti.com/product/TL071Thank you.
Here's the relevant bit of the schematic I wish to build and use separately, thanks. It's outlined in red.
Quote from: Chris Wilson on March 07, 2017, 03:51:33 pmHere's the relevant bit of the schematic I wish to build and use separately, thanks. It's outlined in red.Maybe I am using the wrong terminology, I want a similar device that can be socketed?
http://uk.farnell.com/webapp/wcs/stores/servlet/Search?catalogId=15001&langId=371&storeId=10166&st=TL071&selectedCategoryId=%5BLjava.lang.String%3B%401b761b76&showResults=true&pf=110132318
All right, all right, no need to rub it in I believe, I believe!
