There's a simple DIY Flashlight kit for about $1.7, called:
"DIY FLA-1 Simple Flashlight Circuit Board Electronic Kit"
Basically, there's a little case, a little PCB and a few components (pretty neat for the price, that a case is included).
There are some "practice" pads, which is interesting:
I'd like to ask you two questions:
1 - How the voltage boost works (battery 1.5 to ~3 for the LED) - I only see an inductor, a resistor, and what looks like a transistor (note that on Banggood I don't see a parts list), I thought it might be a "Joule Thief" type circuit. But, the inductor has 2 pins - I don't see a center tap. There are usually 4 pin chips, e.g. QX5252 for solar lights which work with a single added inductor, which determines the current, but the kit has a 3 pin part, whatever the part may be exactly. Perhaps there are 3 pin variants of similar ICs. There's a marking "161007" on the PCB, but I wasn't able to find what that might be.
2 - Any interesting modifications that could be made, perhaps using the "practice" pads on the PCB. One I can think of is maybe adding a small li-po battery and minimal amount of necessary components, but the micro-USB port would require a new hole in the case. I'm not sure if the flashlight would be used so frequently that a rechargeable lithium is an interesting upgrade.
Considering just the parts (case, a nice on/off switch, built-in battery holder) and the price it seems like an interesting thing to get. What are your thoughts about this simple kit?
