Author Topic: DIY...ish Bluetooth Mic  (Read 1479 times)
Offline skillz21Topic starter
« on: October 08, 2016, 11:19:29 am »
Hi guys!
I want to make this, wireless/bluetooth with this. is it possible to do this? also, can i couple two of the recievers/transmitters up so that i basically get a wireless audio... link? (i don,t think its possible, just wondering).
Thanx! :-+
ps.fast responses appreciated :)
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
Re: DIY...ish Bluetooth Mic
« Reply #1 on: October 08, 2016, 11:23:28 am »
Check signal levels, you might need an amplifier between the two.
« Reply #2 on: October 08, 2016, 11:27:08 am »
between the mic and the transmitter? How powerful would it need to be?
Offline deephaven
    • Deephaven Ltd
« Reply #3 on: October 09, 2016, 03:45:02 pm »
The spec's aren't too clear, but you might be able to get away with a direct connection. If you don't mind taking a risk, you could always try getting them and see if they work together. If you then need a bit more gain, you could get something later.
