Thank you Lightages! I suspected that, but it's better to ask.
Correct me if I'm wrong but there are two main difference between the D and E model.
The E has a built in Power meter, which can measure power up to 2500W, but it can measure power continuously for ~1100W. Abow that it can only do it for 5sec, otherwise it will be fried. It's because the 71 series can measure current continuously up to 5A. Above 5A you can only mesure it for 5sec and then you have to wait a few minutes.
The D model doesn't have the power mode, but it has a very much larger internal log capacity. Which is useless, since I can make a device, that reads the measured data from the IR LED and logs it into an SD card. It became an almost infinite logger, it's just that I can't read it back with the DMM.
Knowing the leaders of my country and the Duty Office they will find out something to make me pay something more, but besides that if I can get it inside my country, the any warranty issues could be handled more easily, but that is just a small issue.
I've also read, that some Uni-t DMMs continuity test isn't the best, but in some cases it's because the test leads have some kind of coating on them. Properly cleaning them or using another another trustworty lead can make it better. It won't make it faster, but I could make it better.
