It would be interesting to determine meaning of LEDs...
From observation X7 is probably 1PPS from the uBlox
X8 probably reflects 1PPS from the CPU
I haven't traced these or checked against the main 1PPS output
So far I haven't seen X2 lit
X3 is lit after power-up but before lock
X4 flashing rapidly is probably GPS locked and discipline running but timing not locked
X4 steady and X5 flashing likely reflects timing locked.
I think I'll just leave negative feedback to a seller for listing obviously failed used items as "New", without spending even more of my time.
I confess that I didn't notice that the ebay item status was "new", probably because they so obviously weren't. The description said "used" though.
I think leaving negative feedback would be unfair - they were listed as OCXOs
not GPSDOs - the fact that some boards actually work is a bonus.
I confess that I quite liked the price so bought a couple more. So I now, like others, have a board where the 5T doesn't work. In my case it was pretty obvious it would not without even powering the board as the screening can was caved in and one of the BGA packages in the 5T cracked in half. The 12V filter inductor was smashed as well.
Does anyone know where to get a LEA 5T or LEA 6T at a sensible price?
