Experimented with status command little bit. Started with unit that stayed power on for about 6 hours without GPS antenna connected. Programmed 'status;<cr><lf>' to a hotkey to send command by one keypress...
Before connection of antenna , X3 and X4 blinked and status returnng 'STATUS=2,A,W;'.
about 20 sec after antenna connection LEDS changed to steady X3 and status started to return 'STATUS=4,A,W;'
Observed brief blink of X3 and pressed a key immediately, got 'STATUS=4,A,I;'... In a second another keypress returned "A.W" again.
Started here to poll it every second or even faster. In a few minutes seen once more switch to "A,I" but again momentarily, just a single reply between "4,A,W"'s...
Got a phone call and was forced to switch my attention to more important things for a 20 min or so.
When returned to this stuff, observed blinking X4 and status switched to 'STATUS=3,O,T;'.
Tried to disconnect antenna. Status almost immediately switched to 'STATUS=2,O,H;'. X3 and X4 started to blink.
Reconnected antenna. Status in a few moments switched to 'STATUS=1,O,H;' for a few seconds, then returned to 'STATUS=3,O,T;'.
Disconnected antenna again. Status almost immediately switched to 'STATUS=2,O,H;'. X3 and X4 started to blink.
Connected another antenna that was indoors and wrapped by aluminium foil (no GPS signal, but normal antenna current). Status almost immediately switched to 'STATUS=1,O,H;'. X3 and X4 continue to blink.
Now it stays in '1,O,H' for about 10 minutes, will look what will happen later.
So, for now I observed following values:
First field - 1,2,3,4... Yet to figure out what it really mean, but seems 1 is for no lock at all, 2 for antenna problems, 3 for timing lock and 4 for position-only lock or maybe position survey mode?
Second field - characters "A" and "O". Can someone imagine that "O" means "Operational"?
Third field - characters "W", "I", "T", "H". Maybe "W" is for "Warmup" or "Waiting", "T" for "Timing", and "H" is for "Holdover"? What may momentary "I" mean then?
