Author Topic: Driving 110vdc load with mosfet  (Read 2373 times)
Offline iceisfunTopic starter
« on: September 13, 2016, 09:49:00 pm »
Hello
I need help finding the correct mosfet to drive this load. I have a bunch of these and I want to drive them with a TTL output.
The ones I have tried seem to have some leakage when gate is pulled down to ground.
https://www.amazon.com/dp/B00LVP267S
Online Zero999
  • 0999
Re: Driving 110vdc load with mosfet
« Reply #1 on: September 13, 2016, 10:09:58 pm »
All MOSFETs leak some current when off.
You could try using a BJT instead, as it will have a lower cut-off current.
« Reply #2 on: September 13, 2016, 11:08:10 pm »
I ordered one up to test it out.
Will getting a much bigger mosfet help?
Online Zero999
  • 0999
« Reply #3 on: September 14, 2016, 08:20:50 am »
No, if anything I would suspect a larger MOSFET would make it worse, not better, since it will have a larger die. A higher voltage, lower current rating may help though.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: September 14, 2016, 08:23:48 am »
Think dumber.  Put a resistor across the LED load!
Or slightly less dumb -- more usefully -- use an incandescent bulb instead of a resistor?  Might be useful, even if it's just as a pilot light?  Idunno.
Sometimes it's simple things. :)
Seven Transistor Labs, LLC
Online Zero999
  • 0999
« Reply #5 on: September 14, 2016, 08:35:44 am »
Duh I don't know why I didn't think of that. lol
It can be a very high value resistor, to minimise the power dissipation, even 1M would probably do.
« Last Edit: September 14, 2016, 10:08:47 am by Hero999 »
Offline macboy
« Reply #6 on: September 14, 2016, 04:32:26 pm »
A small incandescent bulb is a very clever idea, Tim. They have a much lower resistance when off/cold, so would be very effective at shunting the leakage current. Then when fully energized, the resistance goes way up and limits the power consumption. A bulb intended for a small plug-in 120 V nightlight would probably work very well.
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
« Reply #7 on: September 14, 2016, 06:31:31 pm »
why are you worried about leakage current? Your 110V LED stripe will be perfectly dark when switched with any suitable MOSFET.
We Are The Watt - Resistance Is Futile!
Online Zero999
  • 0999
« Reply #8 on: September 14, 2016, 06:42:07 pm »
MOSFETs generally have a leakage current of 1µA or more, which is enough to dimly light white LEDs.
All that's needed is a resistor in parallel with the LED rope to reduce the voltage to below the LED strings' forward voltage. An incandescent lamp would do but I suspect it's overkill. A 1M resistor will draw 110µA when the LEDs are on and have <1V across it due to the MOSFET's leakage current.
