A simple beginner's question.
I have a speaker from an old transistor radio. It is marked 8ohm, 0.3W.
Using power formulas and Ohm's law I calculate that to get 0.3W from 8ohms I need about 1.5V and 193mA.
OK, no problem.......so far.......
But would that be Peak voltage/current or RMS?
My thinking is that the heating effects of 0.3W would be averaged over many cycles and therefore RMS is the correct answer.
But then there is this niggling thought that with 0.3W RMS the peaks are going to exceed that and since there is probably very fine wire in the speaker which could heat up and melt quickly I should be thinking in terms of the peaks of the cycle.
Or, I guess I could just use the engineering practice of derating for safety's sake and limit input to about 0.15W?
Any guidance?
Thanks...
earl...
