I want to control an SCR (on /off) with an Arduino Nano.
The SCR is connected to 300 to 400V DC derived from mains but this is isolated from the mains.
Currently I have just connect an I/O pin of the Arduino to the gate through a 220ohm resistor but this was not working properly I could measure voltage above 5V coming back into the I/O pin then I added a 1N4148 diode in series with the 220ohm resistor but even this setup doesn't seem to work out and the work at the I/O pin seems to drop to around 2.5V.
I'm using Pin D2 to drive the gate of the SCR.
Is is mandatory to drive the SCR via a opto coupler? Are there any other drive circuits that will work reliably.
