Those leds typically have a forward voltage of 6v , since there's two diodes in each package. Then you have several of them in series, usually 5 to 8 or something like that... basically you need 30 to 45v like the people above me say to get them working.
The current is probably 100 mA for each led or something that would make them use around 1w at most (1w/6v = ~ 166mA) but to be on the safe side, limit the current to 10-20mA .
If you don't have a power supply that can limit current, you can build something quickly with any lm317 linear regulator or some other fixed voltage linear regulator, just look in the datasheets at example circuits.
