Hello everyone,
I have a project with 4 LED, after some searching on my usual supplier(mouser), I found just what I wanted, the CREE CXA1512-0000-000N00M40E5, problem is, they are only available with the 37v, the 18v ones are out of stock.
I choose this model because of size/lumens/angle and because I allready have the expensive connector with heat sink for it so I'll stick with it.
Problem is the usual driving method was ONE switched managed boost converter --> FOUR switch managed buck constant current, but my design does not reach 37v on the output.. so I need a new one..
I want sugestions for two things, first, are there any options to this :
[SM BOOST CONVERTER] (from 11v~14v to 40volts out 2AMPS )
--> [SM BUCK CONSTANT CURRENT] --> LED (must reach 350mA @ 37v )
sugestions for the boost and constant current regulators, many thanks
