please Mechatrommer tell me why I shall select DS1054 Z not DS1102E?
I shall tell the problem, I am controlling a 3 phase motor, the 3 phase motor is controlled by Large contactors , the contactors are controlled by relays on the PCB, this is my 2nd PCB design, in the first design the microcontroller was freezing on any motor operation, in the 2nd design I cared for the ground signal return paths and separated Relays ground from digital ground, the microcontroller is now fine, the problem is with LCD and 24C64 i2c eeprom, the LCD display garbage when the contactors operate, and the 24C64 eeprom is not responding until I completely disconnect power from PCB at all and reconnect it.
another trick I did , the 5v output from 7805 regulator is splitted to two paths, one for microcontroller and other for remaining ICs, each path has series shotkey diode and after the diode a 1000uf capacitor.
I thought the oscilloscope shall help me to debug this problem.
kindly tell me what shall I do as this project is very important.
