and you must be an expert, are you? No, don't answer this, simply read what i wrote i learn from it.
Likewise...
aha, is he your gay friend or what? Seriously, he can speak for himself, and you should really stop using "magic ball"
When comparing noise levels, you have to be sure to compare like-for-like in terns of noise bandwidth. Most TDS700 series scopes are 500 MHz, so they're bound to show more noise on any given signal than a 70-200 MHz scope. If you have a TDS700 then you know you can filter the bandwidth down to 50 or 200 MHz and observe the difference. Have you tried this?
Andy, of course i've checked before i posted anything. But hey, here a picture, extra made for you:
If you're interested in comparing the noise levels between the two, measuring the calibrator signal is pointless anyway. A calibrator signal is non-critical;
and did i ever said "it is important"?
nvr0hk asked about and he got an answer.
Maybe you should simply read what i wrote:
And I still think that is a pretty lousy calibration signal fom the tekway...
no doubt, but for probe calibration good enough ^^ . It think it could be easy modified, but well, for what? That's only cal signal.
the quality of this signal is quite incidental to the quality of the scope overall - and if you want to measure the noise level of the scope's front end amplifier and ADC stage, you can (and should) do so with it GND coupled or shorted out at the BNC socket.
Invalid comparison - the noise bandwidths aren't the same. The Tek is bound to show more noise than the cheap scope unless it's set to the same bandwidth. If it doesn't, then the cheap scope has a front end which is inherently noisier.
Andy,
stop using "magic ball", to have an opinion about something you should buy or loan it and test it.
You should not even trust on measurments done by others. But hey, i've made a schematic of these Tekway/Hantek DSOs
https://www.eevblog.com/forum/chat/hantek-tekway-dso-hack-get-200mhz-bw-for-free/?action=dlattach;attach=12233so you can download it, analyze and tell me what you think^^.
I personally don't really care that much about the quality of Tekway's frontend, designed to work properly up to 500MHz,
used by Rigol in their 300MHz DSOs, so i assume it was properly tested.
For my old eyes the noise level of the frontend, the parts used and the build quality is more than suficient and can
beat many other scopes. There are other things i don't like, simply check my thread (i should call it book)
https://www.eevblog.com/forum/chat/hantek-tekway-dso-hack-get-200mhz-bw-for-free/That doesn't look particularly flat to me - but even so, it's a very difficult measurement to take correctly. Do you have a function generator with an accurately calibrated, flat output, and an excellent quality 50 Ohm coaxial cable linking it to the scope? Was the scope set to 50 Ohm input or properly terminated some other way at the BNC input? If not you'll get standing waves set up in the cable due to the reflection at the ends, which will depend on the quality of termination and will change with cable length.
i call ± 0.4dBm as good enough, especially due the fact that my signal gen (calibrated R&S SMX)
can have ±0.25dBm deviations between 10MHz and 250MHz.
Of course it was properly terminated, and i definitely not using cheap china or what so ever crap terminators, cables,
splitters, attenuators, etc. It is not that they can't build things, sure they can, but then there is no price difference
to good known products, so no need to "support" them here. And all these cheap things on ebay, they simply useless.
The measurement you've made is just as easily explained by poor measurement technique as it is by the scope not having a flat response. Try some experiments with different settings and different cable lengths, you'll see what I mean.
I'm sure i know how to measure such simple thing. What i know as well, if i would make mistake, i would tell it.
This is a common misconception, a long ground lead doesn't result in a scope "picking up" noise to any significant extent. It does, however, result in noise which already exists on the GND of the source being probed
i would not sign this, the noise picked up already by the common ground is one thing, the extra noise picked up by
"ground lead antenna" is extra thing. If there would be no difference and extra noise, a shorter lead would not change anything.
It looks from your final images as though this scope doesn't actually have a proper intensity graded trace after all. Shame. I had it down as a reasonable model let down by a poor UI, but it seems it's not actually as capable as I thought.
you got that wrong, it does have intensity graded trace.
The point here was that a "static" pixel (or resulting line), when the fw is using 2pix grading, is having only one color for both pixels - sure it is static. Hameg however is here using two colors (so far i can see from other ppl picutres), which makes the line thiner for human eyes.
To be taken seriously, and not just dismissed as yet another not-quite-finished Chinese product (regardless of where it's actually designed and built), what it really needs is a UI overhaul from someone with specialist experience in this area and some properly decent graphic design skills. It's an area in which the established quality manufacturers (I'm thinking Agilent and Tektronix here) are streets ahead, and it makes a huge difference.
Yeah, they did it, on chinese way ... The UI of their previous Tekway model was 1:1 copy of TEK TDS2000 UI:
The current model is however using slightly modified version, many things are still "stolen" from TDS2000 (icons, menus, messages) , some other from DPO2000 (dual window, how FFT will be displayed). I don't know, for someone who always worked with TEK only i don't see here bad things,
i would said i like it.
The only really annoying thing is the color UI color palette, TEK blue and black(gray) are ok, but yellow, green and pink are
for me personally "too much of china engineering" (or maybe i'm too old or not gay enough)
