Author Topic: dual power supply  (Read 1724 times)
Offline paex30Topic starter
dual power supply
« on: July 19, 2018, 08:02:35 am »
Hi everyone,
I wanted to design a simple dual power supply +-15V from a 24 V. Few months ago I found a video on EEVblog youtube channel where a dual power supply was designed simply using OPAMPs. Is there anyone who could remember what video it is or could have some suggestions to design the power supply?
Thanks
Offline +Mikie
Re: dual power supply
« Reply #1 on: July 19, 2018, 11:14:29 am »
What you're asking should be easy to find on the net. But I would simply go for an IC voltage regulator, 7815/7915 for example if you only need fixed voltages. No need for mucking around with op amps. For adjustable there's that LM-something adjustable regulator name which I can't remember at the moment.
For schematics you can have a look at the manufacturers sites, look for "Application notes", but there should be basic schematics in the IC datasheets.
« Reply #2 on: July 19, 2018, 12:38:30 pm »
For this kind of IC you need generate a negative voltage but I have only positive 24 V and I want my design to have a low cost, so I think to use a flybuck converter with transformer or only OPAMPs.
Offline Zero999
  • 0999
« Reply #3 on: July 19, 2018, 01:08:48 pm »
Hi everyone,
Thanks
What is it powering?
It's possible the circuit can be modified to work with a single supply rail.
How much current is needed?
Can't you use a rail splitter to get +/-12V?
« Reply #4 on: July 19, 2018, 01:15:58 pm »
I need a +-15V with a maximum current of 170 mA per channel.
Offline schmitt trigger
  • Country: mx
« Reply #5 on: July 19, 2018, 01:55:18 pm »
A 30 volt voltage span from a 24 volt input.
No. Definitively you are not going to get it with a purely linear regulator. You do require switchmode regulators.
There are some of options:
1- Two regulators, a buck and an inverting regulator fed each from +24 volt. No transformers, only two inductors.
2- A pushpull converter. This would be my preferred for higher power, but you require an output transformer with both primary and secondary center taps and two inductors.
3- Because the output power is low, a flyback converter would also work, but you still require a transformer with two secondaries. But no inductors.
« Last Edit: July 19, 2018, 01:56:57 pm by schmitt trigger »
Offline HB9EVI
« Reply #6 on: July 19, 2018, 02:01:11 pm »
As we all see, there isn't yet much skill, already in the way the question is asked; I don't see much sense in proposing to build switching mode regulators; more meaningful would be to get small a center tapped 18V 10VA transformer and work with the 7815/7915 or LM317/337 if variable voltage is needed.
Offline Lee Leduc
« Reply #7 on: July 19, 2018, 03:21:01 pm »
Unless you're set on designing and building your own, the easy solution is to buy a DC/DC converter. Take a look at a DC/DC converter like the Murata NDS6D2415C. 24VDC in, +/-15VDC at 200ma out.
Stock https://octopart.com/nds6d2415c-murata+power+solutions-49451068
Datasheet https://datasheet.octopart.com/NDS6D2415C-Murata-Power-Solutions-datasheet-8452589.pdf
About $20 USD. You'll have to check price and availability in your country.
Offline +Mikie
« Reply #8 on: July 20, 2018, 12:39:40 am »
There is such a thing as capacitive voltage multiplier, invented long time before all this IC stuff. It would be quite feasible for such a low current.
However, save yourself a world of complications and start with a centre-tapped transformer of at least 18V per side. Again, at such a low current it will be small and cheap. Follow that with ANY linear regulator, IC or discrete and that's it.
Offline Zero999
  • 0999
« Reply #9 on: July 20, 2018, 02:11:44 pm »
To power what?
It's quite likely you could re-configure the circuit to use a single 24V power supply, if you told us what the circuit is.
