Hi. I have an Agilent E3615A single output isolated power supply rated for 35V at 1.7A. It has the +ve and -ve terminals together with a mains earth terminal. Instead of getting a dual output tracking power supply for dual polarity use such as with opamps, would it be possible to connect the +ve terminal of the E3615A to the positive power rail, the -ve terminal to the negative power rail and connect the mains earth to the ground?
Would this configuration even work? Of course, the circuit will not be isolated anymore and one would have to be careful where one connects the ground leads when probing with a scope to avoid shorts. If it does work, are there any drawbacks?
Thanks.
