WARNING WILL ROBINSON...
You said you have the dimmer controlling wall outlets.
This can be very dangerous to anything other than incandesant lamps plugged into these outlets.
God only knows what would happen to a switch mode power supply if it was plugged in.
Most mains powered house hold items other than refrigerators, microwave ovens dish washers washing machines use switch mode power supplies.
Most domestic dimmers are also ONLY CAPABLE of handling up to about 500 watts.
They DO NOT operate compact fluorescent bulbs and even LED globes are not the best with a dimmer.
ALSO driving a transformer supplied device i.e. stereo amp through a dimmer NOT ON. edited......
Check out BIG CLIVE
https://youtu.be/fWh2obSY0dQ https://youtu.be/_4PwYm_7HKg around the 14 minute mark re inductive loads edited......
Please reconsider your way of dimming lamps.
DIMMING WALL OUTLETS IS A NO NO...
BILL.
