Hi
I have ordered lots of different op amps and I am trying them out on Daves dummy load circuit as they arrive. I am using a 10k pot, a irfz44n mosfet and a single 100 watt 1 ohm resister as current source for a meter and checking this against a inline multimeter . A lm358 works either fully on or fully off no matter what voltages .A single lm741 will not take negative feedback from the mosfet source pin but works beautifully when sourced at the gate and is very accurate. Putting a car headlight bulb before the mosfet takes heat away from it and still I get very acurate meter readings.Two mosfets in direct parrallel do not share the load equally and require a ballast resister on the source.Some say this works without ballast but I have found it not so.One was cold and the other burnt my fingers but warmed up when I removed the hot one.
