Hello everyone,
I would like to measure H-field and E-field energy in low frequencies (0-100kHz). All the probes I find for those purposes are mostly 100kHz upwards, and generally oriented towards the MHz and GHz range.
Do you have any suggestions for good probes for my range OR a way of generating exact (reference) amount of energy in H/E-field so I could possibly calibrate my own sensor (inductor) for the measurements?
Thank you very much!
