They probably are fakes. I just looked at TEquipment.net, authorized Fluke dealer, and their price is $28.85 USD. Check out Frankie's store on eBay and look at the Brymen leads. I have a set and I like them:http://www.ebay.com/itm/Brymen-Silicone-Gold-Plated-Test-Leads-Probes-for-Multimeters-CAT-IV-1000V-/171162377470?hash=item27da129cfe:g:uSQAAOxyTjNShpch
Unless Fluke branding is important to you, another option is to look at Pomona, they make the Fluke test leads and you can pick up Fluke test leads with the Pomona branding and not be concerned about the quality.
Quote from: blacksheeplogic on May 14, 2016, 09:21:38 pmUnless Fluke branding is important to you, another option is to look at Pomona, they make the Fluke test leads and you can pick up Fluke test leads with the Pomona branding and not be concerned about the quality.I also suggest this, look for example at Pomona 6365 (straight plugs) or 5519A (L shaped plugs, same as TL-71). They also come in kit with alligator clips and tip extenders (look for 6344 and 6343)
