Take a look at page 6 figure 12 of the data sheet.Assuming static operation, the current and voltage must be below the line DC.
Quote from: mij59 on August 06, 2014, 05:34:19 amTake a look at page 6 figure 12 of the data sheet.Assuming static operation, the current and voltage must be below the line DC.so it looks like if you connect a 10V power supply you should be able to pull 4A. or am I reading the graph wrong?
If the opamp could provide a gate-to-source voltage of 6.5V would I be able to pull 12A?
I'm using fqp50n06l in my own load, but i've used the slightly modified circuit shown here : http://www.sleepyrobot.com/?p=136And it's not a transistor, it's an n-channel mosfet
oh okay, thanks. so do you know a transistor that could handle more current off the top of your head? (that could be used in the original circuit)the FQP30N06L seems like a good candidate, but I'm not sure.
Quote from: waspinator on August 06, 2014, 08:59:32 pmoh okay, thanks. so do you know a transistor that could handle more current off the top of your head? (that could be used in the original circuit)the FQP30N06L seems like a good candidate, but I'm not sure.Dissipation of 80W is not possible, the temperature of the junction gets too high, the thermal resistance is too high.A TO247 package transistor would be better, e.g. IRFP460.
