Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
EEVBlog uCurrent output to oscilloscope
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: EEVBlog uCurrent output to oscilloscope (Read 2631 times)
veryevil
Supporter
Country:
on:
November 06, 2012, 08:39:40 am »
Hey, quick question. Can Dave's uCurrent be connected to an oscilloscope to see the current waveform? Does it not something in between or is it just not possible?
Thanks
Logged
Rerouter
Super Contributor
Country:
Question Everything... Except This Statement
Re: EEVBlog uCurrent output to oscilloscope
Reply #1 on:
November 06, 2012, 08:41:50 am »
its an op amp amplifying the signal across a small resistance value, you may get some ringing on fast signals, but it should operate like any other op amp circuit,
Logged
deephaven
Frequent Contributor
Country:
Civilization is just one big bootstrap
Reply #2 on:
November 06, 2012, 09:01:25 am »
Yep, I've done that, it works a treat.
Logged
Simon
Global Moderator
Country:
Did that just blow up? No? might work after all !!
Reply #3 on:
November 06, 2012, 09:56:56 am »
you will of course be limited by the bandwidth of the uCurrent so don't expect it to have perfect representation for higher frequencies, checking the specs of the opamp should tell you all you need to know.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
